Greetings all...
I'm trying to replace the Electronic Controll assembly for my KitchenAid Diswahwasher (KUDS01FLSS6). I have the part and can unconnect the wiring, but can't figure out how to remove the part from the dishwasher panel. It is held into place with ridgid clips that I don't want to break. Any help out there? Thanks!
There is only one way how to remove the control board: carefully use a flat bladed screwdriver to depress the holding tabs at the left end of the control board housing while pulling up.
Originally Posted by: Gene  There is only one way how to remove the control board: carefully use a flat bladed screwdriver to depress the holding tabs at the left end of the control board housing while pulling up.
Gene. Gene...Thanks for that reply. I actually finally figured that out yesterday. The confusing thing for those that have this issue is that the board is shipped in a grey casing that one might think needs to be completely used to replace the board/casing already there. In fact you need to remove the board as you said and simply go board for board. Tahnks Again!!!
