gmors
#1 Posted : Monday, October 27, 2008 6:37:52 PM(UTC)
gmors
I have a GE side by side, both the freezer compartment and fresh food sides are warm at top (50F) and cold at bottom (15F); replaced evaporator fan motor (comes with a connected bullet type themostat that clamps to evaporator coils); still has same symptoms; is this a circuit board problem or ?? Thanks
kayakcrzy
#2 Posted : Tuesday, October 28, 2008 4:24:56 AM(UTC)
kayakcrzy
If the fan did not come on, when you replaced it, you would need the motherboard. Tom ApplianceEducator.com
gmors
#3 Posted : Tuesday, October 28, 2008 2:45:22 PM(UTC)
gmors
thanks Tom, sorta suspected that
gmors
#4 Posted : Saturday, November 29, 2008 10:20:55 AM(UTC)
gmors
just as suggested, I replaced the motherboard and evaporator fan kicked on and everything is working, fyi to all-I sourced the motherboard for $59.95 plus $11.00 shipping at McCombs Supply Co in Lancaster, PA. Nice enough people. Be aware, the board I received looked quite a bit different from the installed one, and had an extra plug-in port; however just plugged in the 6 leads I had in same general location on new board and all is working. The new boards with the extra port must fit several models with other options I don't have. Hope this helps somebody!
kayakcrzy
#5 Posted : Sunday, November 30, 2008 5:12:10 AM(UTC)
kayakcrzy
That is an amazing price on that board. Tom ApplianceEducator.com
Guest (5)
Warm at top, Cold at bottom (Refrigerator & Freezer Repair)
by NotCold inAK 7/6/2014 3:07:33 PM(UTC)
