mikejcars
#1 Posted : Monday, October 27, 2008 5:41:07 PM(UTC)
mikejcars
my gas dryer has heat for about 5 minutes then it is gone. the fuse has source voltage and the other sensor in the air outlet has 120volts at all four wires it seamed the switch went open then closed. after that you can see the ignition glowing but no more flame. if it sits off for a few minutes it will ignite again and do the same thing
misterfixall
#2 Posted : Monday, October 27, 2008 6:05:50 PM(UTC)
misterfixall
it sound as if the gas valve solonoids are failing
mikejcars
#3 Posted : Monday, October 27, 2008 6:35:11 PM(UTC)
mikejcars
could the mode timer switch have anything to do with this it was stuck on some settings and moves on others opened up the switch and contacts were burned up I ordered it and re installed now I have this problem. tried to clean the contacts did not do anything. have not received new timer yet
misterfixall
#4 Posted : Monday, October 27, 2008 6:52:02 PM(UTC)
misterfixall
try replacing burner valve solonoids
mikejcars
#5 Posted : Monday, October 27, 2008 6:56:35 PM(UTC)
mikejcars
any idea on how to get them the model # dose come up and I have no idea how old this is it was in the house when bought
libertyappl
#6 Posted : Monday, October 27, 2008 7:10:47 PM(UTC)
libertyappl
What's your model number?
Nat
misterfixall
#7 Posted : Tuesday, October 28, 2008 4:04:04 AM(UTC)
misterfixall
if you open door you should see sticker on body where door meets body
