my gas dryer has heat for about 5 minutes then it is gone. the fuse has source voltage and the other sensor in the air outlet has 120volts at all four wires it seamed the switch went open then closed. after that you can see the ignition glowing but no more flame. if it sits off for a few minutes it will ignite again and do the same thing
it sound as if the gas valve solonoids are failing
could the mode timer switch have anything to do with this it was stuck on some settings and moves on others opened up the switch and contacts were burned up I ordered it and re installed now I have this problem. tried to clean the contacts did not do anything. have not received new timer yet
try replacing burner valve solonoids
any idea on how to get them the model # dose come up and I have no idea how old this is it was in the house when bought
What's your model number? Nat
if you open door you should see sticker on body where door meets body
