3 Pages123>
m218perez
#1 Posted : Monday, October 27, 2008 3:37:21 PM(UTC)
m218perez
My GE Monogram 42" side by side built-in refridgerator with water, crushed and cubed ice dispencer from door stopped dispencing. It will still dispence water and make ice, but won't dispence crushed or regular ice from the door.
I know the auger is not turning, this is what pushes the ice out. It stopped working after crushing ice for about ten minutes for a party we had. Possibly I burned somthing out, any ideas?
thanks,
Mike
#2 Posted : Tuesday, October 28, 2008 11:50:53 AM(UTC)
Hi Mike,
Did the ice door open when you push the lever? Did you hear any noise?
m218perez
#3 Posted : Tuesday, October 28, 2008 3:16:17 PM(UTC)
m218perez
Gene,
The ice door does open and I hear a buzz.
Thanks for your reply,
Mike
#4 Posted : Tuesday, October 28, 2008 6:48:41 PM(UTC)
Mike,
Check for 120VAC to the auger motor with the door switches depressed and the ice dispenser calls for ice. The wires should be removed from the motor.
m218perez
#5 Posted : Tuesday, October 28, 2008 8:46:39 PM(UTC)
m218perez
Gene,
I will look for a motor access panel and get back to you Thursday.
Mike
m218perez
#6 Posted : Thursday, October 30, 2008 1:44:43 PM(UTC)
m218perez
Gene,
I am looking behind the ice bin and I see several screws and bolts against the back panel. It also looks like I would need to remove the auger fork to remove the panel, am I looking in the right area? or should I be looking above the freezer where I see a mother board.
Mike.
josephterrazas
#7 Posted : Thursday, October 30, 2008 3:09:04 PM(UTC)
josephterrazas
hello Gene, I'm having the same problem my GE makes ice but doesn't dispense. Do I need to replace motor?
#8 Posted : Thursday, October 30, 2008 4:27:13 PM(UTC)
Mike,
You have to remove the ice bin, the ice maker and the cover for the motor & solenoid (#813 on the break down diagram). You do not have to remove the fork for this test. You can test the solenoid for continuity at the same time.
#9 Posted : Thursday, October 30, 2008 4:28:56 PM(UTC)
josephterrazas,
What is the complete model number of the refrigerator? You have to perform some tests to find out which part is bad.
m218perez
#10 Posted : Thursday, October 30, 2008 9:34:16 PM(UTC)
m218perez
Gene,
Thank you for the info, I am so busy at work right now I have small windows of time and energy to trouble-shoot this fridge. Saturday I will try opening the panel and check the motor and selenoid.
Thanks again, Mike.
Guest (7)
3 Pages123>
