dosbirn
#1 Posted : Monday, October 27, 2008 11:28:28 AM(UTC)
dosbirn
The glass stove top shattered and I was wondering if I could replace it myself. It looks the glass only can be replaced (instead of the entire porcelain/glass stove top). There is a rubber gasket between the glass and the porcelain top. Is this something I can easily do myself? Would it require some type of glue? How difficult would it be to seal the gasket (and glue, if necessary)? (Note: the zero in my model number is correct according to the plate on the stove, however, I think the GE website drops the "zero" in the model number).
Thank you,
Debbie
libertyappl
#2 Posted : Monday, October 27, 2008 12:20:54 PM(UTC)
libertyappl
Debbie,
The "glass" top comes in the porcelain frame. What is the color of the "glass" which is actually a crystal material?
Nat
dosbirn
#3 Posted : Tuesday, October 28, 2008 6:33:34 AM(UTC)
dosbirn
The glass is black (I guess) with white or grey speckles all over the glass. Except the burner areas are solid black (no speckles) with white/grey circles outlining them (if I remember correctly - I'm not at home right now).
libertyappl
#4 Posted : Tuesday, October 28, 2008 7:11:21 AM(UTC)
libertyappl
What color is the porcelain?
dosbirn
#5 Posted : Tuesday, October 28, 2008 11:43:45 AM(UTC)
dosbirn
Sorry...it's white.
Thanks!
libertyappl
#6 Posted : Tuesday, October 28, 2008 12:50:46 PM(UTC)
libertyappl
It could be part # WB62T10457 or WB62T10463 there are a few part numbers.
Nat
dosbirn
#7 Posted : Tuesday, October 28, 2008 1:21:37 PM(UTC)
dosbirn
I did find the first part # also (elsewhere on the internet). I have some limitation on this computer (at work) so I'll try to check it out both part numbers on my computer when I get home.
Thanks for you help, Nat!
libertyappl
#8 Posted : Tuesday, October 28, 2008 1:31:59 PM(UTC)
libertyappl
Anytime!
Nat
dosbirn
#9 Posted : Tuesday, October 28, 2008 3:57:10 PM(UTC)
dosbirn
Okay - I looked up both part numbers at this website and no pictures load. Also, I'd like to find a diagram of the stove but nothing is coming up for my model #. Any idea where I can find that?
I noticed you attached the part numbers as links but when I click on them, I get the "IE cannot display this page" error message. Any idea how to get pictures of the stove top and a diagram of the stove?
In the mean time, tomorrow I will try to contact GE to get the correct replacement stove top part #.
Thanks, Nat.
