I looked through your article about error codes and didn’t see my code listed. I get an error code F10. Is this code the same as an F1 or F0 or unrelated? The problem I’m having is; our oven on occasion turns off and flashes this code. Sometimes we can push the clear button and everything works all right and sometimes it don’t. Any help would be appreciated.
It sounds like the clock control board has a relay heating up on it. You will most likely have to replace it, sooner or later. Tom ApplianceEducator.com
