ltfuzz
#1 Posted : Saturday, October 25, 2008 6:53:20 PM(UTC)
ltfuzz
relay starter replaced 2 years ago. Now same problem. Repairman replaced with 3 n 1 starter relay. Started right up but lasted less than 24 hours. Compressor or ad relay? Technican says he did everything he could an it must be compressor.
#2 Posted : Sunday, October 26, 2008 3:35:53 AM(UTC)
For the "newer" refrigerators with less than a 1/4 horsepower compressor, the use of a 3n1 hard start kit will burn out the start winding. Also, if the run capacitor was not connected, this will cause the compressor to fail.
If you find the run capacitor missing, I would take a picture of this and show it to the guy's boss.
Generally, the use of a hard start 3n1 kit will void the compressor warranty.
ltfuzz
#3 Posted : Sunday, October 26, 2008 6:39:32 AM(UTC)
ltfuzz
Any chance a new relay starter will fix problem? I'll try it myself if theres a chance.
icehouse
#4 Posted : Sunday, October 26, 2008 3:43:40 PM(UTC)
icehouse
Use a URCO 410 this is for units with a run capacitor. :)
#5 Posted : Monday, October 27, 2008 1:13:57 AM(UTC)
I would be VERY surprised if a kit like icehouse suggested worked, may be worth a try though.If you have a meter, check the compressor for blown windings/shorts to ground.
ltfuzz
#6 Posted : Wednesday, October 29, 2008 6:14:09 AM(UTC)
ltfuzz
thanks all. Will try using repair manual from app.
Possible Bad Compressor??? (Refrigerator & Freezer Repair)
by bonesteel 12/27/2013 6:57:19 PM(UTC)
Do I throw away a 2009 upright freezer or replace bad compressor? (Refrigerator & Freezer Repair)
by rbuske 7/31/2013 10:33:15 AM(UTC)
GE Refrigerator Bad Compressor? (Refrigerator & Freezer Repair)
by rohman 2/17/2012 11:04:38 AM(UTC)
bad compressor?? (Refrigerator & Freezer Repair)
by svotta 9/5/2011 11:28:17 AM(UTC)
by kord78 4/18/2011 9:10:45 AM(UTC)
GE SxS refrig/freezer not working - bad compressor? (Refrigerator & Freezer Repair)
by brian008 2/18/2009 4:29:07 PM(UTC)
