kflack
#1 Posted : Wednesday, May 28, 2008 5:36:48 PM(UTC)
kflack
Hey,
My maytag dishwasher is displaying E3 just before it finishes its cycle....
I have misplaced my manual and was wondering if anyone would happen to know what it means? I dont want to call a repair man out if its just a blocked drain!
If anyone could help I would really appreciate it!
Thanks you
kflack
#2 Posted : Wednesday, May 28, 2008 5:41:13 PM(UTC)
kflack
The model number is MJD2000AAW!!!!!!!!!
#3 Posted : Thursday, May 29, 2008 2:55:39 PM(UTC)
The model number you posted does not come up.
Is it an American model? If it is - verify the model number and repost it.
If it is a Canadian model - unfortunately we are not able to find any information.
imeyer
#4 Posted : Friday, October 24, 2008 7:12:37 PM(UTC)
imeyer
I have the same model Maytag MJD2000AAW Dishwasher with the same problem the E3 Error message, Did you have any luck with the repair? Im located in Australia.
imeyer
#5 Posted : Friday, October 24, 2008 7:32:44 PM(UTC)
imeyer
I have the same model Dishwasher Maytag MJD2000AAW, with the same error message, I have the manual, but it does not give any information on the E3 error message.
Have you resolved your problem, or did you find out what was wrong?
competitions
#6 Posted : Sunday, February 15, 2009 2:35:54 PM(UTC)
competitions
Hi
I experienced the same E3 error some weeks back. I called the repair man and a circuit board was replaced. All has been well until today when it did the E3 again. Hopefully it was a one off error, if not I'll be looking for competition to the original repair firm used.
I have the manual and the error details are as follows -
E1
Cause: Water supply switched off.
Remedy: Switch off appliance. Turn on water supply. Reset the cycle.
E2
Cause: Problem with electronic temperature control.
Remedy: Call service for assistance.
E3
Cause: The water heater element does not work properly or the filter mesh is blocked.
Remedy: Clean the filter mesh and if the problem continues please contact service
E4
Cause: The appliance does not discharge water.
Remedy: Check that the discharge hose is not bent, syphon is not blocked, filters are not blocked.
Hope that helps!
