I just bought an overload relay kit and right before putting snapping it back onto the compressor I noticed that one of the prongs from the compressor is deformed, I assume it got so hot it started to melt. It's the top right prong that goes into the relay (there are three prongs, two on top and one on bottom). ![UserPostedImage](http://www0.mediafire.com/imgbnc.php/01e9276f3256deb024c725adff0710d5cc1397cfcb74437aa0f4a6b8dfa720252g.jpg) Does this mean I have to buy new compressor? Or Can I heat the prong up and mold it back into shape? Second question is that the new kit did not have a capacitor (black box) that plugs onto the back of the white relay, I'm not sure if it got damaged or not, so I will put the old one back on, will the fridge work if it is and is it absolutely necessery to have it?
Buy a dremmel ( a small, hand held portable drill like a electric screwdriver) and grind it round.
I have one, the question now is how important is that prong? If I grind it out it would become shorter than the other two, will this be hazard or problem?
