Larry Phillips
#1 Posted : Tuesday, October 21, 2008 7:51:01 AM(UTC)
Larry Phillips
Changed the timer,Electronics about a year and a half ago. The only thing that wouldn't work was the clean cycle, after pushing the key pad it finally went into a clean cycle once. Now if the oven sets for a couple hours it start beeping and the codes F1 and F0 are displayed and you can't get it to shut off for a minute or so and the only thing that works on the key pad is the bake cycle so I have pulled the touch pad wiring grid out and the only thing that works is the clock until we need the oven and than I reinsert the wiring grid. I believe it is the touch pad panel am I correct?
#2 Posted : Tuesday, October 21, 2008 8:33:11 PM(UTC)
Hi Larry,
Yes, you were right. The problem is a bad touch pad aka a control panel.
- The part number for the control panel is AP4284805
Here are the break down diagrams for the Jenn Air range Model W2780B
Larry Phillips
#3 Posted : Wednesday, October 22, 2008 7:56:42 AM(UTC)
Larry Phillips
Thanks for your assistance and I am in the process of ordering a new one. Again thanks
#4 Posted : Wednesday, October 22, 2008 11:49:25 AM(UTC)
You are welcome Larry. Keep us posted.
