don419
#1 Posted : Wednesday, October 10, 2007 9:36:10 AM(UTC)
don419
I replaced the defrost timer and the heater and the fuse on breaker blows when it goes into defrost. Any suggestions?
don419
#2 Posted : Wednesday, October 10, 2007 10:48:45 AM(UTC)
don419
Could it be the thermostat?:rolleyes:
Pegi
#3 Posted : Wednesday, October 10, 2007 1:06:45 PM(UTC)
Pegi
Could be, something in the defrost circuit is shorted to the case, might by-pass it for a test only and check the wiring for a bare wire touching metal...
don419
#4 Posted : Wednesday, October 10, 2007 2:02:48 PM(UTC)
don419
I went step by step first I turned the defrost timer to defrost, the new heater worked it came on and turned red. then I turned the defrost timer to come out of defrost and the breaker blew could the thermostat be the problem? once I get out of the defrost cycle the breaker can be reset.
#5 Posted : Friday, October 12, 2007 3:33:40 AM(UTC)
You could have a shorted wire right by the defrost timer, just look for arc marks.
don419
#6 Posted : Friday, October 12, 2007 6:51:23 AM(UTC)
don419
Thank you for help! You are appreciated Don.
Guest (4)
