I replaced the defrost timer and the heater and the fuse on breaker blows when it goes into defrost. Any suggestions?
Could it be the thermostat?:rolleyes:
Could be, something in the defrost circuit is shorted to the case, might by-pass it for a test only and check the wiring for a bare wire touching metal...
I went step by step first I turned the defrost timer to defrost, the new heater worked it came on and turned red. then I turned the defrost timer to come out of defrost and the breaker blew could the thermostat be the problem? once I get out of the defrost cycle the breaker can be reset.
You could have a shorted wire right by the defrost timer, just look for arc marks.
Thank you for help! You are appreciated Don.
