The plastic blade on the auger in the icemaker started cracking, so I ordered a new auger from you. We just received our replacement auger (AP3672963) and I began taking the icemaker apart so that I could replace the cracked auger. I can't get the stupid thing out!! Any tips on how to replace it?
Hi Laurel,
In order to provide the most accurate advise I need the complete model number of the fridge.
Hi Gene, Thank you for responding! The model number is GSS22WGMCC.
Turn over the ice bucket and ice dispenser cover. Remove the Phillips screw. Remove the cover. Remove the Phillips screw for the ice cube control linkage and slide the linkage to the rear of the ice bucket. Using a pair of pliers, break the tabs off the back cover. Using 2 flat blade screwdrivers, disengage the locking tabs at either side of the ice crusher and remove the assembly Slide the back cover off the auger. The back cover must be replaced because of tabs broken off for disassembly. With a flat-head screwdriver, remove the C-clip from the end of the auger. Remove the auger and ice crusher blade assembly.
Thank you, I really appreciate that!
Gene,
Can you please give the next step? I've completed removing the auger with ice crusher assembly. I've got my new auger but can't seem to get the ice crusher assembly/blades off the old one. It appears to just unscrew but I can't seem to get it to budge. I think it has reverse threads but I've tried both directions. Any tips or does it come off some other way?
thanks marty
