Laurel
#1 Posted : Tuesday, February 26, 2008 2:57:53 PM(UTC)
Laurel
The plastic blade on the auger in the icemaker started cracking, so I ordered a new auger from you. We just received our replacement auger (AP3672963) and I began taking the icemaker apart so that I could replace the cracked auger. I can't get the stupid thing out!! Any tips on how to replace it?
#2 Posted : Wednesday, February 27, 2008 12:24:05 PM(UTC)
Hi Laurel,
In order to provide the most accurate advise I need the complete model number of the fridge.
Laurel
#3 Posted : Wednesday, February 27, 2008 12:28:35 PM(UTC)
Laurel
Hi Gene,
Thank you for responding! The model number is GSS22WGMCC.
#4 Posted : Wednesday, February 27, 2008 12:57:46 PM(UTC)
Turn over the ice bucket and ice dispenser cover. Remove the Phillips screw.
Remove the cover.
Remove the Phillips screw for the ice cube control linkage and slide the linkage to the rear of the ice bucket.
Using a pair of pliers, break the tabs off the back cover.
Using 2 flat blade screwdrivers, disengage the locking tabs at either side of the ice crusher and remove the assembly
Slide the back cover off the auger. The back cover must be replaced because of tabs broken off for disassembly.
With a flat-head screwdriver, remove the C-clip from the end of the auger.
Remove the auger and ice crusher blade assembly.
Laurel
#5 Posted : Wednesday, February 27, 2008 1:14:17 PM(UTC)
Laurel
Thank you, I really appreciate that!
mdmahoney1
#6 Posted : Wednesday, October 22, 2008 7:31:48 AM(UTC)
mdmahoney1
Gene,
Can you please give the next step? I've completed removing the auger with ice crusher assembly. I've got my new auger but can't seem to get the ice crusher assembly/blades off the old one. It appears to just unscrew but I can't seem to get it to budge. I think it has reverse threads but I've tried both directions. Any tips or does it come off some other way?
thanks
marty
