witt
#1 Posted : Tuesday, October 21, 2008 7:13:03 PM(UTC)
witt
Like some of the others, I'm not getting heat, or at least consistent heat. Took off the back of the dryer, shop vac'd the lint out, and ran the dryer with the back off (and the vent unhooked). Thing fired right up and was HOT in seconds inside.
Thought I had fixed it, put it back together and the vent pipe back on, started it up and it was cold, cold, cold.
Does that help narrow down what is wrong? I didn't see anyone with quite the same issue.
v2k04
#2 Posted : Tuesday, October 21, 2008 7:18:47 PM(UTC)
v2k04
you probably jossled something check the power cord and outlet for proper line voltage first
witt
#3 Posted : Tuesday, October 21, 2008 7:57:30 PM(UTC)
witt
it's a gas dryer... could the power cord still be the issue?
v2k04
#4 Posted : Wednesday, October 22, 2008 3:08:02 AM(UTC)
v2k04
thats a whole different story
kayakcrzy
#5 Posted : Wednesday, October 22, 2008 4:35:26 AM(UTC)
kayakcrzy
I believe the back being off is not an issue. Turn the dryer on, and see if the ignitor comes on. If it does, replace the coils on the gas valve. Also a model # would help us help you. But check the ignitor first. Tom ApplianceEducator.com
