markrwilcox
#1 Posted : Tuesday, October 21, 2008 6:52:20 PM(UTC)
markrwilcox
Microwave is not a DACOR...it is a DANBY that was not in the list.
Whenever the door is shut the microwave is up and running. Works great other than the fact that the only way to shut it off is to open the door.
v2k04
#2 Posted : Tuesday, October 21, 2008 7:14:48 PM(UTC)
v2k04
It has a bad interlock switch in interlock module its were the door latches and trips the switches usually there are three of them a primary a secondary and a monitor switch
markrwilcox
#3 Posted : Tuesday, October 21, 2008 7:49:33 PM(UTC)
markrwilcox
I figured it out!!! On the main circuit board[GAL9823] there are 2 "black boxes"(Galanzjd2-1A 12vdc 16A 12v....) when you remove the wires from either of the boxes and use a tester to test for continuity there should be nothing. Both of them showed continuity. I took another circuit board out of another Danby microwave(that I found in the dump....that one only numbers 1-3 would work on the touch pad) I swapped the circuit boards and it works great!!!!
v2k04
#4 Posted : Wednesday, October 22, 2008 3:10:36 AM(UTC)
v2k04
good for you ,,,,what luck huh?
markrwilcox
#5 Posted : Thursday, October 23, 2008 12:39:33 PM(UTC)
markrwilcox
mighty...doesnt usually work that way....
Guest (4)
