AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Replace Control Board - Help to Remove Front Panel
Hello. Purchased a new control board from AppliancePartsPros.com and am now trying to replace the defective part. Got the dryer top cover off no problem but not sure how to remove the front panel to gain access to the control board assy. Should have ordered a manual! :( Any ideas on where to download a service manual or a few tips on how to get the front panel off? Thanks!
Perfect - was exactly what I needed! Had to remove the whole front panel to get the control assembly off. Replaced control board and now works like a champ! Glad I did the work as there was a lot of accumulated lint inside that I was able to clean out. May need to replace the foam gasket between the front panel and blower at some point but at lease I know how to keep after it now. Thank for your help!
Well great, glad we were able to help and you got it going. Really glad you saw to clean it out, built up lint is the major cause of dryer failure.
Good luck, and thanks for the update.
Dryer Repair
