smiller990
#1 Posted : Friday, March 25, 2011 2:46:14 PM(UTC)
smiller990
Hello. Purchased a new control board from AppliancePartsPros.com and am now trying to replace the defective part. Got the dryer top cover off no problem but not sure how to remove the front panel to gain access to the control board assy. Should have ordered a manual! :( Any ideas on where to download a service manual or a few tips on how to get the front panel off? Thanks!
sidfink43
#2 Posted : Sunday, March 27, 2011 7:27:59 AM(UTC)
sidfink43
See if this link doesn't get you to a service manual for your model.
http://frigidaireservicetips.co...icElectronicControls.pdf
smiller990
#3 Posted : Monday, March 28, 2011 8:42:47 AM(UTC)
smiller990
Perfect - was exactly what I needed! Had to remove the whole front panel to get the control assembly off. Replaced control board and now works like a champ! Glad I did the work as there was a lot of accumulated lint inside that I was able to clean out. May need to replace the foam gasket between the front panel and blower at some point but at lease I know how to keep after it now. Thank for your help!
sidfink43
#4 Posted : Monday, March 28, 2011 9:15:40 AM(UTC)
sidfink43
Well great, glad we were able to help and you got it going. Really glad you saw to clean it out, built up lint is the major cause of dryer failure.
Good luck, and thanks for the update.
