2 Pages12>
shawn1991
#1 Posted : Tuesday, October 21, 2008 6:29:36 AM(UTC)
shawn1991
i picked this thing up and the guy that had it did some home made repairs with electrical tape, duct tape and bare wire....he burnt up all the thermostats and fuse...i have all of them new and i am trying to rewire it back to the manfacturers standards but dont have a schematic for this exact model...i have some schematics for the newer kenmores that have the heating element in the back...this one is on the bottom under and to the right of the tumbler drum if looking at it from the front...if anybody has a wiring diagram or schematic for this model # or older style of kenmore/whirlpool dryer i would really appreciate it..shawn
libertyappl
#2 Posted : Tuesday, October 21, 2008 7:14:05 AM(UTC)
libertyappl
Shawn,
The schematic should be in the console of the dryer.
Nat
shawn1991
#3 Posted : Wednesday, October 22, 2008 3:49:26 AM(UTC)
shawn1991
i know that is where they usually are...i got this one off the side of the road and it didnt have it....
libertyappl
#4 Posted : Wednesday, October 22, 2008 9:38:35 AM(UTC)
libertyappl
This one should be very close, it has the same wiring harness.
Nat
File Attachment(s):
Wiring Sheet - 3406688 dryer.pdf (238kb) downloaded 78 time(s).
shawn1991
#5 Posted : Friday, October 24, 2008 4:50:43 AM(UTC)
shawn1991
thanks..ill compare it to what i have and take another crack at that dryer...reason..i am thinking i am wrong is cause im only reading 110 at the heating element...that should be 220 correct?...
libertyappl
#6 Posted : Friday, October 24, 2008 6:04:02 AM(UTC)
libertyappl
Correct, If you are only getting 110V make sure your have 220V at the wall plug.
Nat
shawn1991
#7 Posted : Thursday, October 30, 2008 5:35:23 AM(UTC)
shawn1991
ok...i took a break from this thing for a while cause i was nukin it...i read my plug and my red has 110...and the black had 110...each leg together makes 220 right??....and then white is ground....am i wrong..cause i am definitly getting 110 at one side of the heating element...this thing also has a circuit card next to the timer...that isnt on the schematic...im lost...help!!!...oh ....God bless your ministry!!!
libertyappl
#8 Posted : Thursday, October 30, 2008 6:05:59 AM(UTC)
libertyappl
Correct you should have 110 on each side and 220 together. You may need to follow the wires thru the harness to see if you have a broken wire or a loose wire in the harness. Found one just a few weeks ago that wouldn't run and it turned out to be a loose connection in the harness plug at the motor. That's the bad thing about Kenmore's getting the correct wiring diargram if the one in the console is no longer there.
And thank you for blessing the ministry.
Nat
shawn1991
#9 Posted : Thursday, October 30, 2008 6:22:53 AM(UTC)
shawn1991
yeah i do have the 220 at the plug....i used another dryer i got and it started right up....that circuit card seems to be ok..i read out all the resistors and the values are correct...ill try and dig thru the harness and see if i can get anywhere...the thing is...it was tumbling when i first got it and that guy had it wired all crazy..now that i undid all that and tried to do it the right way i aint getting the 220 to the motor or the element...its weird....if you got anymore suggestions that would be great...im an electrician in the navy and started working on washers and dryers in my garage for extra money...teaching myself all this stuff and picking up tips from this website....anyway...thanks again...
libertyappl
#10 Posted : Thursday, October 30, 2008 6:41:28 AM(UTC)
libertyappl
If your wanting to learn more go to www.servicematters.com there;s all kinds of information there, of course it's all whirlpool & maytag products.
Nat
Guest (7)
2 Pages12>
