chief455
#1 Posted : Sunday, October 19, 2008 9:52:53 AM(UTC)
chief455
great machine, but since 3 more people moved in it rinses/spins fine but clothes are still very wet unless extra spin cycles are used.
Also - it is slow to fill on the "cold water" setting. Cold water runs feely elsewhere in the house.
I see the water pump is available for ~$35 - should I get one before I start digging in? Also - for my machine is their any related parts typically need replacing during a pump swap?
the machine is difficult to access.
thank you!
#2 Posted : Monday, October 20, 2008 9:00:58 AM(UTC)
Originally Posted by: chief455 Go to Quoted Post
...1) clothes are still very wet unless extra spin cycles are used.
2) Also - it is slow to fill on the "cold water" setting. Cold water runs feely elsewhere in the house...
1) Pull the washer out, remove the rear cover and check all hoses for a clog.
2) Replace the water inlet valve (#805 on the break down diagram).
- The part number for the water inlet valve is AP2618763
Here are the break down diagrams for the Hotpoint washer Model WLW3500RBL
chief455
#3 Posted : Monday, October 20, 2008 6:09:12 PM(UTC)
chief455
thanks Gene! no concern it may have a weak pump? that seems to be a common reply to poor drain issues.....
#4 Posted : Tuesday, October 21, 2008 12:00:03 PM(UTC)
The most common problem with this particular pump is water leak but...you never know.
