hej
#1 Posted : Monday, October 20, 2008 12:12:21 PM(UTC)
hej
During washing cycle (before soap dispenser door opened), dishwasher stopped with water in bottom. Would not resume working and none of the control panel buttons were illuminated. Could not cancel and restart. Breaker ok. What's wrong and how do I repair this?
#2 Posted : Monday, October 20, 2008 1:58:16 PM(UTC)
Check for 120VAC at the power outlet.
Remove the bottom panel, open the junction box on the right side and check the power cord connection to the dishwasher.
Open the control panel and check the thermal fuse (on the side of the control board box) for continuity.
- The part number for the thermal fuse is AP3178588
hej
#3 Posted : Monday, October 20, 2008 2:05:43 PM(UTC)
hej
Thanks for the help; I'll will check. On the fuse in the control panel, anything special I need to do to replace it? Also, photo on parts website does not match diagram in Sears parts manual.
#4 Posted : Monday, October 20, 2008 5:36:36 PM(UTC)
Nothing special, just follow the installation instructions included with the part. Sears probably has old pictures.
hej
#5 Posted : Tuesday, October 21, 2008 6:43:57 AM(UTC)
hej
Ok, thanks.
