richardt
#1 Posted : Monday, October 20, 2008 9:46:24 AM(UTC)
richardt
When setting my oven temp above 350, after a few minutes the oven door pops open slightly then closes. Like if an expolsion has happened inside. I also smell gas. When set to 350 this does not happen. This started after I replaced the igniter. What could be causing this.
#2 Posted : Monday, October 20, 2008 1:37:47 PM(UTC)
Check if the igniter installed in the right position. When the gas valve opens, the gas should ignite within 2 seconds or less. Also check the burner for any burned through holes. Check the flame - the air mixture probably needs an adjustment.
richardt
#3 Posted : Monday, October 20, 2008 3:07:29 PM(UTC)
richardt
Is the air mixture adjustment something that a sharp home owner can do or is this time to call a service technician in?
#4 Posted : Monday, October 20, 2008 6:11:00 PM(UTC)
There is a ring on the bottom of the burner (where it comes to the gas valve). You have to rotate this ring to adjust the air mixture.
Caloric oven door pops open when ignited (Oven Repair (including Ranges and Cooktops))
by sruliz 10/10/2015 8:47:27 PM(UTC)
