Chris611
#1 Posted : Sunday, October 19, 2008 2:44:09 PM(UTC)
Chris611
I have a GE washer that is having problems. The first sign was the machine was not spinning and then motor would be very hot. Once the motor cools, it will run if I manually turn the pully some. At times the larger pulley is very hard to turn. Sounded like a slight dragging sound coming from the brake area. So I pulled the tub/transmission. When I pulled the metal frame work from the bottom of the tub, the black gasket/brake pad that the disk rubs on is cracked. Can this cause the brake to drag? Is there another adjustment on the brake? Can I replace just this "brake pad"? Any help would be great.
Chris
v2k04
#2 Posted : Sunday, October 19, 2008 7:16:40 PM(UTC)
v2k04
You're going to need a whole transmission if I'm understanding your post.
#3 Posted : Monday, October 20, 2008 1:33:42 AM(UTC)
Unfortunately, they do not sell the brake shoes for this although I read where someone replaced his brake shoes, probably from a junked washer.
Chris611
#4 Posted : Thursday, October 23, 2008 4:24:16 PM(UTC)
Chris611
Well, I have been trying to fix my machine. Seems that now the brake is dragging. Is there a way to adjust this? When I eyeball the disk, it looks like when it is fully retracted (in the released state), it just barely gets below the brake pad/base. What has changed or worn out? Any advice. I don't know where to look next.
Thanks again
Chris
#5 Posted : Friday, October 24, 2008 12:48:46 AM(UTC)
No adjustment for the brake shoes. Just try to get a used set.
v2k04
#6 Posted : Friday, October 24, 2008 3:34:09 AM(UTC)
v2k04
If your machine is under 5 years the transmission is under warranty but the labor is not
Guest (4)
