greg c
#1 Posted : Monday, March 21, 2011 9:59:59 PM(UTC)
greg c
The lower oven works fine - the upper oven looks to be working; preheat comes on, timer counts down, all lites normal but it doesn't get warm during or after countdown. Countdown is longer as it should be when oven set for a higher bake temp
Note: Broiler inop also.
Any ideas?
I'm going to swap elements from lower oven to upper but can't imagine both upper elements could have gone bad at the same time . . .
Are there diagrams available with test points & values that can be downloaded?
Other suggestions please . . . And thanks in advance!
greg c
greg c
#2 Posted : Thursday, March 24, 2011 11:48:24 AM(UTC)
greg c
Resolved. Found other posts by Nat which answered question.
Thanks Natalie ("Nat" of Liberty Appliance Service) Big Help! and dang good at what she does!! :D
greg
Magic Whirlpool Dbl Oven (Oven Repair (including Ranges and Cooktops))
by Ljcme 11/27/2015 2:41:09 PM(UTC)
whirlpool dbl oven gry/white wire grounded now oven wont come on. (Oven Repair (including Ranges and Cooktops))
by driftman11 1/16/2013 5:56:59 PM(UTC)
New Whirlpool dbl oven loud fan (Oven Repair (including Ranges and Cooktops))
by jgleas 12/19/2012 2:37:46 PM(UTC)
Whirlpool DBL Oven Self Cleaning Failure (Oven Repair (including Ranges and Cooktops))
by utahute 11/27/2010 6:02:16 PM(UTC)
Error Code Whirlpool DBL Oven (Washer Repair)
by ccervantes 8/6/2010 6:21:59 AM(UTC)
Whirlpool Dbl Oven E6 F2 code (Oven Repair (including Ranges and Cooktops))
by themalones1995@gmail.com 12/29/2009 11:07:03 AM(UTC)
Whirlpool dbl oven (Oven Repair (including Ranges and Cooktops))
by kayna222 10/6/2009 5:19:17 AM(UTC)
Whirlpool dbl oven - clock blank (Oven Repair (including Ranges and Cooktops))
by mcof 11/12/2008 7:10:19 PM(UTC)
