4 Pages<1234>
dh1200s
#11 Posted : Tuesday, March 22, 2011 3:02:12 PM(UTC)
dh1200s
Ken,
You will only need QTY (2) 6207-2RS only two.
Did you read through the post I asked you to Google on the FIXYA forum?
""FAV6800AW, SN#15.... top loader Unit is very"" if you cant find the post I will post a direct link.
It is important that you understand that one of the bearings in the Outer Tub is a split bearing. One half of that bearing assembly is a standard ball bearing the other half of that bearing is a One-Way bearing.
Maytag in their infinite wisdom moved the functionally of the Upper One-Way bearing ring to I believe the Lower Outer Tub bearing. That bearing assembly cannot be found with all the looking I did.
You will uses a standard 6207-2RS bearing QTY (2) one for the Upper and one for the Lower Outer Tub bearing . From this post ""FAV6800AW, SN#15.... top loader Unit is very"" please read all comments that the Series 15 owner had to do with his Outer Tub bearing replacement&#8230;&#8230;you will have to do the same thing. You will have to shim out that Lower Bearing when you install the Spinner Nut because of the bearing thickness of the Maytag change in Outer Tub design.
The Spinner Support bearings are;
Upper Bearing Splined Shaft ride in this bearing it&#8217;s a 6002-2RS
Lower Bearing Clutch pulley end is a caged needle bearing. INA SCE-910 http://www.wholesalebearing.com/nrcagetype.html or other bearing suppliers.
Also a couple of pics to remove the shim from the Spinner Support if you haven't already done that. Most of this info is called out in this post FAV6800A/FAV9800A Outer Tub bearing replacement
Here is a pic of the two Spinner support bearings. I feel it is a wise decision to replace both of them at this point of the tear down&#8230;&#8230;&#8230;&#8230;Good Luck..........Dick
dh1200s attached the following image(s):
dh1200s
#12 Posted : Wednesday, March 23, 2011 5:19:06 AM(UTC)
dh1200s
Ken,
The INA SCE-910 caged needle bearing for the Lower Spinner Support bearing (Clutch Pulley side) was purchased from these folks.
""I got the INA SCE-910 caged needle bearing from Eureka Bearing Inc. Hunting Beach Ca. 714-895-3555 just tried the number and went to their VM. Their p/n for the SCE-910 seems to penciled in on the box as J-910.""
I did place that info in this post FAV6800A/FAV9800A Outer Tub bearing replacement
You may try local to your area and get it cheaper.
Are we clear on what you have to do for replacing that split bearing assembly in your Outer Tub rebuild?
ken P
#13 Posted : Wednesday, March 30, 2011 7:39:34 PM(UTC)
ken P
Hello Dick.
I have compleated the outer tub rebuilb that we were going over on my maytag neptune FAV6800AWQ. Everything went as we had talked about, and seems to run like new.However it only runs through short spin cycles after starting it up, never had a problem with the electronics before
Is there a sequance that I need to go through to re-set the electornics after the power was turned off to the unit?
Best Regards
Ken. :rolleyes:
dh1200s
#14 Posted : Wednesday, March 30, 2011 9:42:45 PM(UTC)
dh1200s
Ken,
Before I answer that question &#8220;&#8221;it only runs through short spin cycles after starting it up, never had a problem with the electronics before&#8221;&#8221;.
I asked if your lower Outer Tub bearing was the dual bearing assembly (was one half of the lower Outer Tub bearing a ball bearing assembly and the other part of the bearing a One-Way bearing) making up the Lower Outer Tub bearing as I show in the pic of post #4 (permalink)?
If the Lower Outer Tub bearing was of that type you had to shim out when you replaced it with the 6207-2RS bearing. If you shimed out what did you use for shims, their thickness and how many?
OK your question; &#8220;&#8221;it only runs through short spin cycles after starting it up, never had a problem with the electronics before&#8221;&#8221;
Let&#8217;s make sure I understand. You select a wash cycle and (with other settings selected) and you press the Start button. Are you saying the machine does not fill with water and run the wash/agitate cycle but goes directly into a short Spin Cycle?
If you can give me all the detail you can and we will proceed with troubleshooting. There is nothing to reset on the Control Board.
I assume nothing is binding after the Outer Tub rebuild. By that I mean with the front cover off and looking down on the Clutch Pulley can you rotate the Clutch Pulley by hand CCW and after a few turns the wash basket should rotate CCW. If you then rotate the Clutch Pulley CW the Tumblers will rotate all with no binding is that correct?
Thru the Lid can you rotate the Wash Basket CCW only is that correct?
I work nights Tue thru Sat 4PM to 12:30AM here on the East Coast. I will try to reply ASAP on your response.......Dick
dh1200s
#15 Posted : Thursday, March 31, 2011 8:15:59 AM(UTC)
dh1200s
Ken,
Doing this with my three thousand mile long screw driver is difficult for me most of the time.
When you mounted your Clutch Pulley did you use the Upper Bearing One-Way Roller Clutch bearing ring?
You have to use that Upper Bearing One-Way Roller Clutch bearing ring when mounting your Clutch Pulley because you have converted back to the old Maytag Outer Tub design........ undoing their redesign back to a more sensible Outer Tub Design using 6207-2RS Outer Tub Bearings for both the Upper and Lower Outer Tub bearings.
Did you add that Upper One-Way Roller Clutch bearing ring on reassembly of the Clutch Pulley?
Dick
ken P
#16 Posted : Thursday, March 31, 2011 9:35:51 AM(UTC)
ken P
OOPS,
Rooky mistake. I over tightened shaft nut.Runs like a new machine now.
Thanks for your help.
Best Regards
Ken.
dh1200s
#17 Posted : Thursday, March 31, 2011 9:53:48 AM(UTC)
dh1200s
Originally Posted by: ken P Go to Quoted Post
OOPS,
Best Regards
Ken.
Ken.
When you have time can you explain?
Which Shaft nut? Spinner Support?
You can educate me now......can you explain what shims you used for the Lower Outer Tub bearing, their thickness and how many, where did you pick them up or did you home brew the shims?
I assume you had to use them and that you reassembled using the Upper Clutch bearing ring above the Clutch Pulley. Is that correct? This info will help other FAV6800A/FAV9800A owners and me with the redesigned Outer Tub.
Thank you.........Dick
ken P
#18 Posted : Thursday, March 31, 2011 12:26:59 PM(UTC)
ken P
Hi Dick.
I did not use the upper clutch bearing, as I could not get it to fit properly. There is not enough room for the assembly. I will have to see how this works out. As for the shims, I went to Low's and found some brass rings used to mount door knob assembley, they look like large washers used in eletrical braker boxes to adjust conduit size. I used 4 of these as they were the perfict fit.Can you tell me the spinners in the drum have pointers on them, do they need to be oriented in a certan way?
Ken.
dh1200s
#19 Posted : Thursday, March 31, 2011 3:17:44 PM(UTC)
dh1200s
Hey Ken
Can you tell me the spinners in the drum have pointers on them, do they need to be oriented in a certan way?""'
On page 39 of the SM they show the alingment of the tumblers. My untouched Series 17 id not dead on. I don't feel it will be an issue if they do not align dead on.
Thank you for the feed back. With out that upper one-way bearing installed can you try this? With the washer lid up can you rotate the Wash Basket in the CW direction.
If so while your washer is in wash/agitate the tumblers rotating. Can you release the washer top from the base and see if it is rotating CW during the wash/agitate cycle?
I assume your Outer Tub did not have notches in the bottom of the tub is that correct?
You read what the Series 15 owner had to do. I don't see what would keep your wash basket from rotating slow CW rotations during the wash/agitate part of the wash cycle. I'm scratching my head.
Thank you.......... Dick
DB App.
#20 Posted : Wednesday, June 15, 2011 1:09:59 PM(UTC)
DB App.
Dick and other members- I did a little follow up on post #18 and have some specs to share. I also plan on installing the early type bearings into a late model tub. (series #16) I did not find any automotive transmission or differential shims that were close in size to the door knob shims recommended in post 18. What the fellow above discovered was a set of door knob adapters acted as the needed thickness to take up the differences in old bearing design verses later designed housing bore depth. Lowe's has a set of door knob to deadbolt adpaters that do indead look like breaker box conduit shims. (that is how I found them and recognized them when I found them) They are item number 1165 in the door knob aisle. There 2 per pack and the fellow above used a total of 4 to complete his washer repair. The O/D is 2 & 3/16". The I/D is a hole 1 & 1/2" diameter. The thickness of the 2 adapters in the blister pack is 3/16" total. All 4 shims would = 3/8" total shim pack thickness for what it's worth. I say if it works why fight it. This will be my first approach when it is time to replace my tub bearings. This is especially important given that the late model bearings do not seem to exsist. As a side note Dick walked me through the "service mode" function and was curious of my cycle count when trouble started. This unit is 6 years old and has done 3735 cycles when the drive clutch needed a quick "rebuild". I am sure a tub seal and tranny o-ring are in the near future. Hopefully I can reseal the unit prior to any water damage to the tub bearings. Dave
4 Pages<1234>
