jamin00
#1 Posted : Tuesday, March 22, 2011 6:16:08 AM(UTC)
jamin00
I'm changing the berrings in the transmission. I have it down to the next thing I need to do is take off the clutch. Has 200lbs of pressure, how would you do it? Whats the trick?
magician59
#2 Posted : Tuesday, March 22, 2011 9:40:54 AM(UTC)
magician59
You're probably refering to the brake assembly. From the bottom of the machine, after you have removed the thrust bearing, you'll notice there are six screws around the circumference of the brake stator. They are 8-32 threaded. If you remove three of them (every other one), and replace them with longer screws of the same thread, you can slowly back them out to release the spring's pressure after removing the short screws.
This will take some time, but will save you about a hundred dollars on the purchase of a brake tool.
Joe / APP Team
#3 Posted : Tuesday, March 22, 2011 1:06:48 PM(UTC)
Joe / APP Team
Jamin,
Without a removal tool,
The basic process is:
Remove one of the screws, from the brake stator,
Take it to the local hardware store and purchase 2 screws(same thread size and pitch) only, 2 to 3 inches long.
Install the 2 longer screws across from each other on the stator, hand tight.
Remove all the other mounting screws, then slowly and evenly remove the 2 longer screws, until the brake rotor spring tension is released.
After the repair, reverse the procedure to install the stator.
Good Luck,
jamin00
#4 Posted : Tuesday, March 22, 2011 2:05:17 PM(UTC)
jamin00
Thanks alot, really helped!!:cool:
Joe / APP Team
#5 Posted : Wednesday, March 23, 2011 5:29:18 AM(UTC)
Joe / APP Team
Jamin,
So you were able to finish the repair ?
Glad, the 2 screw trick, worked for you, it's a lot cheaper than a brake removal tool( that trick has been around for ages,as well ).
Good Luck,
Interesting Question - Sanyo Window AC - Please Answer (Heating, Ventilation, and Air Conditioning (HVAC))
by Vikas11111 4/22/2024 4:10:50 AM(UTC)
Whirlpool Refrigerator question (Dishwasher Repair)
by staffx4 1/9/2024 11:15:21 AM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Viking VGR30-4B Oven Rack Supports question (Oven Repair (including Ranges and Cooktops))
by awsnap 10/12/2023 4:14:12 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Fridge/Freezer Question and issues? (Refrigerator & Freezer Repair)
by dapapers1 7/13/2023 11:40:18 AM(UTC)
ATC question (Washer Repair)
by Guest 5/13/2023 6:44:26 AM(UTC)
Part Number question (Dishwasher Repair)
by jacob3204 2/7/2023 12:10:28 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
compressor start relay question (Refrigerator & Freezer Repair)
by Guest 10/16/2022 2:45:39 AM(UTC)
Why is there a question at the start of the advertisement? (General Talk)
by williamfrancis 10/7/2022 1:55:32 AM(UTC)
WT5001CW question (Washer Repair)
by corvairbob 7/22/2022 7:09:20 AM(UTC)
samsung rf31fmesbsr evaporator fan voltage question (Refrigerator & Freezer Repair)
by jimmye4golf 7/20/2022 8:30:42 PM(UTC)
kenmore elite front loader question (Washer Repair)
by corvairbob 7/12/2022 4:15:48 PM(UTC)
used direct drive questions (Washer Repair)
by direct-drive 6/28/2022 2:09:13 PM(UTC)
