JTY
#1 Posted : Sunday, March 20, 2011 5:17:11 PM(UTC)
JTY
Our Kenmore Dryer is not fully drying cloths. I held down latch and turned dryer on. It got hot for about 2 minutes then quit heating, it then started heating again but only lasted about 2 minutes again before it quit heating again. Which sensor do I need to replace, and where is it located?
Thanks,
JTY
#2 Posted : Monday, March 21, 2011 2:05:51 AM(UTC)
If I understand your post you were checking it by running with the door open. The unit will not operate correctly as there is no air flow over the heating coils so you will run off the high limit thermostat and also may blow the thermal cut-off.
I would check/clean your vent system first.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
JTY
#3 Posted : Monday, March 21, 2011 6:36:00 AM(UTC)
JTY
Thanks for the quick reply. The vent system is clear. With the back off I run the dryer and watch the heating elements. They come on and then cycle off after approx 2 minutes. The dryer doesn't stay hot enough to dry the clothes.
Thanks,
JTY
#4 Posted : Monday, March 21, 2011 12:39:09 PM(UTC)
Replacement parts for KENMORE 11064642400 | AppliancePartsPros.com
See the attachment for your wiring diagram
Looking at the parts when the unit is on high heat the thermostt turns the heat of at 155 degrees F and then comes back on at 130 degrees F.
You could check this with a thermometer.
Also when the unit was disconnected from the vent did you have good air flow?
File Attachment(s):
64642400.pdf (214kb) downloaded 7 time(s).
JTY
#5 Posted : Monday, March 21, 2011 5:28:28 PM(UTC)
JTY
Thanks, I changed all three thermostats and it fixed the problem.
Thanks for your help,
JTY
#6 Posted : Wednesday, March 23, 2011 12:48:27 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
Odd Kenmore Dryer Model number (Dryer Repair)
by adamm53 3/2/2024 3:42:02 PM(UTC)
Kenmore Dryer blowing thermal fuses (Dryer Repair)
by Marius 11/21/2023 2:26:28 PM(UTC)
Kenmore Dryer stops running after start button is released (Dryer Repair)
by Jbee14 7/30/2023 11:15:53 AM(UTC)
Kenmore Dryer spinning cold air nonstop until the door is open (Dryer Repair)
by Guest 5/15/2023 10:22:27 AM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
Kenmore dryer issue when heat is on (Dryer Repair)
by Guest 2/2/2023 2:17:08 PM(UTC)
Kenmore Dryer Model:86984110 (Dryer Repair)
by CarolynC143 10/23/2022 5:00:36 AM(UTC)
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 5/5/2022 8:17:09 PM(UTC)
Repair manual for Kenmore dryer model 110.85081401 (Washer Repair)
by Guest 5/5/2022 2:29:52 PM(UTC)
kenmore dryer wiring (General Talk)
by epyveras 3/24/2022 7:04:26 AM(UTC)
KENMORE DRYER WIRING 796.813 (Dryer Repair)
by Guest 3/24/2022 7:00:58 AM(UTC)
Kenmore Dryer Model 110.76752500 Parts (Dryer Repair)
by redknitter 2/23/2022 7:24:03 AM(UTC)
kenmore dryer powers up with lights on, push start and it chirps and that is all (Dryer Repair)
by Guest 10/14/2021 7:53:03 PM(UTC)
Kenmore Dryer 41790052990 (Dryer Repair)
by Guest 3/26/2021 4:59:53 PM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
