Found puddle on floor after dishwashing. Removed front cover near floor on front of DW. Water dripping from center of unit. What am I getting into if I want to do the repair?
THIS FORUM IS DEAD!!!!!!! |
Thanx Denman for the links. Will ck things out.
Hi Denman!!! Did the deed!!! Removed DW from undercounter. Noticed that the motor bracket was rusted. Removed 2 screws and took off the bracket. Was able to pull by hand the motor exposing the 2 O rings. Both rings were very flat looking. I found no other areas on the bottom of the DW that looked like they had a leak or had been leaking. What do you think???
Questions- if I replace the rings will I just have to follow the process described above in reverse? Or will it be a more pressue type fit because the rings are new? If so do I need some type of lubercation?
[COLOR="DarkRed"]What do you think???[/COLOR] Sounds like you found it
[COLOR="DarkRed"]Questions- if I replace the rings will I just have to follow the process described above in reverse? Or will it be a more pressue type fit because the rings are new?[/COLOR] Yes to both but should not be a huge problem.
[COLOR="DarkRed"]If so do I need some type of lubercation?[/COLOR] I always put a light coating of grease on O-rings, seals etc, when doing any plumbing. They go in easier and have less tendency to grab and twist. Also when I have to take it apart 5 years from now it is easier as the scale does not stick to them. I use white lithium grease as it has good temperature resistance and is white so I do not get all dirty but just about any grease will do. Margarine works in a pinch. Clean where they fit into and also give that area a light coating. |
Hi!!! I will order the rings. Luv white lithium me ownself!! Upon arrival, I will lube things up, replace the parts and reinstall the DW. Thank you for your good resources and assistance.:D
Good luck with it.
Since you have to pull it apart you might as well open the pump up and clean/check it. |
All went well with the reinstall after I replaced the rings. Per your suggestion I ck'd the pump and did find debris. Again, thank you for your input and helpful links!!!!:D
