2 Pages12>
RIP
#1 Posted : Tuesday, October 14, 2008 4:24:12 PM(UTC)
RIP
Coils are clean, fan is running and makes a engage noise every 1-2 minutes and compressor is not starting.Help please!
Drags1998
#2 Posted : Tuesday, October 14, 2008 5:30:31 PM(UTC)
Drags1998
My guess is that the RELAY-OVERLOAD on the Compressor has failed,If this is a whirlpool built unit, its quite common, Please list the COMPLETE Model#
RIP
#3 Posted : Tuesday, October 14, 2008 6:17:20 PM(UTC)
RIP
10650562991, Whirlpool built Kenmore. Thank you!
libertyappl
#4 Posted : Tuesday, October 14, 2008 6:23:38 PM(UTC)
libertyappl
Drags is probably correct, there are a few posts on here for testing components, But you should(if not already done) unplug the unti. Don't want a simple relay/overload issue to become a sealed system problem.
Nat
RIP
#5 Posted : Tuesday, October 14, 2008 6:40:33 PM(UTC)
RIP
Thank you, I was hoping it would be something simple like that. Yes, it is unplugged now but it went a whole day until my wife told me about the problem. Do you think that may have caused additional damage??
libertyappl
#6 Posted : Tuesday, October 14, 2008 6:43:01 PM(UTC)
libertyappl
Was it still clicking often?
Nat
RIP
#7 Posted : Tuesday, October 14, 2008 7:01:06 PM(UTC)
RIP
Yes it was, Thanks John
libertyappl
#8 Posted : Tuesday, October 14, 2008 7:06:13 PM(UTC)
libertyappl
Ok, test the relay first, it should be a little white colored box attached to the compressor, take it off and shake it, if it rattles that's probably your problem.
Nat
RIP
#9 Posted : Tuesday, October 14, 2008 7:20:07 PM(UTC)
RIP
That is it, it actually looks like it was burned up, plastic is cracked open and is white around it. Thank you so much!!
libertyappl
#10 Posted : Tuesday, October 14, 2008 7:21:29 PM(UTC)
libertyappl
Hopefully the relay will get you going!!
Let me know if you need the part number.
Nat
2 Pages12>
