when starting load the washer fills but does not stop filling and overflows, does not advance to agitate cylcle
When it does this unplug the washer, if it keeps filling you have a fill valve that is stuck open, if it stops filling there is something wrong in the water level circuit like a stuck fill level switch or the hose to the switch has come loose or has a hole in the hose...
thanks oeggi it was a cut hose on the fill switch
Cool, thanks for letting me know...;)
Originally Posted by: Pegi  When it does this unplug the washer, if it keeps filling you have a fill valve that is stuck open, if it stops filling there is something wrong in the water level circuit like a stuck fill level switch or the hose to the switch has come loose or has a hole in the hose... I had the same overflow problem and I already changed the water level switch to no avail. I unplugged the machine and found that the cold water valve kept filling up. Is this repairable or do I need to buy a new one?
