cherokeedave
#1 Posted : 18 years ago
cherokeedave
when starting load the washer fills but does not stop filling and overflows, does not advance to agitate cylcle
Pegi
#2 Posted : 18 years ago
Pegi
When it does this unplug the washer, if it keeps filling you have a fill valve that is stuck open, if it stops filling there is something wrong in the water level circuit like a stuck fill level switch or the hose to the switch has come loose or has a hole in the hose...
cherokeedave
#3 Posted : 18 years ago
cherokeedave
thanks oeggi it was a cut hose on the fill switch
Pegi
#4 Posted : 18 years ago
Pegi
Cool, thanks for letting me know...;)
gullagej
#5 Posted : 18 years ago
gullagej
I had the same overflow problem and I already changed the water level switch to no avail. I unplugged the machine and found that the cold water valve kept filling up. Is this repairable or do I need to buy a new one?
