I'm not sure which model GE fridge I have but it's a side by side refrigerator/freezer with ice maker, water dispenser etc. and it's 6 years old .The freezer works fine but the fridge is freezing all the food and I guess it froze up the water line too because no water will come out of the despenser. Might this be a bad thermostat inside the fridge that controls the compressor?
Any ideas?
Originally Posted by: kc10ken  I'm not sure which model GE fridge I have but it's a side by side refrigerator/freezer with ice maker, water dispenser etc. and it's 6 years old .The freezer works fine but the fridge is freezing all the food and I guess it froze up the water line too because no water will come out of the despenser. Might this be a bad thermostat inside the fridge that controls the compressor?
Any ideas?
Thanks Yes give us a model number the psychic network is off. :D
MY FRIG IS FREEZING UP. THE FREEZER IS FINE WHAT IS THE PROBLEM:confused:
Originally Posted by: rosssmith  MY FRIG IS FREEZING UP. THE FREEZER IS FINE WHAT IS THE PROBLEM:confused: Could be a number of things. A model number helps a great deal. :)
Originally Posted by: rosssmith  MY FRIG IS FREEZING UP. THE FREEZER IS FINE WHAT IS THE PROBLEM:confused: Model #FR26H5SB5 Frigidaire side by side
My firg is freezing up. The freezer is fine what is the problem. Model # FR26H5ASB5 Frigidaire
Check the fresh food damper control. :)
