Dale Z
#1 Posted : Monday, October 13, 2008 3:03:59 PM(UTC)
Dale Z
After using the microwave in this combo wall unit, I noticed the panel was dark with no PF and no error codes. However, I could still use the microwave with the add a minute feature, but the oven would not work. The panel would only beep. I flipped the breaker to reset and left it off overnight, but that didn't help. I am figuring it is the control panel, but maybe it is a control board (after reading some other posts). Do I need both parts, or does the panel come with the board, or do you think I have another problem altogether? Thanks.
Dale Z
#2 Posted : Monday, October 13, 2008 3:12:07 PM(UTC)
Dale Z
Additionally, now it doesn't even beep; can't use the microwave or oven at this point.
#3 Posted : Tuesday, October 14, 2008 11:54:45 AM(UTC)
Hi Dale,
Open the control panel and remove the wire plug for the low voltage transformer from the control board. Check for 120VAC between the P16-6 & P16-7 terminals (where the transformers Red wires connected).
If there is nothing wrong then check for 20VAC between the P16-2 & P16-3 transformer terminals.
If there is nothing wrong then replace the control board.
- The part number for the transformer is AP3968801
- The part number for the control board is AP3175501
Here are the break down diagrams for the Whirlpool oven/microwave combo Model GMC305PDQ5
Dale Z
#4 Posted : Monday, October 20, 2008 5:36:34 PM(UTC)
Dale Z
Gene, I replaced the control panel and now it says Error Code 1, Fault Code 2. According to the spec sheet it now says this means Touch Pad should be replaced. Do you agree?
#5 Posted : Tuesday, October 21, 2008 11:57:48 AM(UTC)
Dale,
Which part did you replace? Control panel and touch pad is the same part.
Guest (5)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
GE Profile Refrigerator Dispenser Control Panel Issue (PFSS6PKXESS) (Refrigerator & Freezer Repair)
by Geprofileman 6/24/2021 6:45:46 AM(UTC)
Frigidaire Gallery FGGF3054MFF Control Panel Issue? (Oven Repair (including Ranges and Cooktops))
by Greyhound88 2/3/2017 6:17:02 PM(UTC)
control panel issue (Oven Repair (including Ranges and Cooktops))
by JULES52 2/12/2013 9:40:05 PM(UTC)
HELP!! Control Panel Issues (Dishwasher Repair)
by claudinemdepaul 7/1/2012 3:26:52 PM(UTC)
FRIGIDAIRE WASHER control panel issue? (Washer Repair)
by BRAD974 5/28/2011 8:44:34 AM(UTC)
Control Panel Issues (Oven Repair (including Ranges and Cooktops))
by paule10204 1/10/2011 11:55:58 AM(UTC)
Whirlpool Wall Oven control panel issues (Oven Repair (including Ranges and Cooktops))
by spkolluri 11/24/2010 10:55:48 AM(UTC)
Control Panel Issues (Washer Repair)
by dkirks 10/21/2010 10:09:56 AM(UTC)
Jenn air Control Panel issue (Oven Repair (including Ranges and Cooktops))
by CShort5 2/13/2010 4:58:02 AM(UTC)
Control panel issues (Oven Repair (including Ranges and Cooktops))
by jgootz 1/19/2010 1:07:55 PM(UTC)
Jenn Air oven control panel issues (Oven Repair (including Ranges and Cooktops))
by tychaney 11/12/2009 12:57:11 PM(UTC)
Whirlpool Control Panel Issue? (Dishwasher Repair)
by bermanbj 8/26/2009 7:47:28 AM(UTC)
Installed today, control panel issues or just me? (Dishwasher Repair)
by Kodge 7/25/2009 5:28:35 PM(UTC)
GE Profile Artica Fridge-Control Panel issue? (Refrigerator & Freezer Repair)
by edeluca62 2/24/2009 2:52:24 PM(UTC)
