flyingfortress
#1 Posted : Monday, October 13, 2008 12:41:11 PM(UTC)
flyingfortress
Hi, my gas dryer stopped heating last night. When I removed the lower panel, I saw that the igniter seemed to be turning on and off as it should
but there wasn't any gas getting to the burner. The gas valve solonoids
seemed to be pretty hot. What I don't know is if they are supposed to be
hot or if they are hot because they are not working and are preventing
gas from getting to the burner. I guess I don't know whether I should
buy the whole burner unit or just the solonoids. Thanks.
v2k04
#2 Posted : Monday, October 13, 2008 2:30:47 PM(UTC)
v2k04
Well most of the time on a Whirlypool gas dryer when the ignitor lights but no gas it's the Primary and assist coils on the valve. Replace both I can't remember if the Thermal kills power to the ignitor or not I'm thinking it does. Been awhile since I worked onm a gas dryer but I'd replace the coils They come together and check the thermal with an ohm meter just to be safe it will be the white plastic lookin one on the blower housing
