wlbowen
#1 Posted : Wednesday, January 20, 2010 9:57:47 AM(UTC)
wlbowen
The door release is not working when I push the 'door open button' on the bottom of the control panel. How do I remove the control panel? Is there screws? Do I pry off the panel? If so, from what direction?
The 'hooks' on the door seem fine, it's the lever that pushes thehe 'hooks' up.
I assume the control panel has to be removed to get to the macanical parts that release the door.
dalemorris
#2 Posted : Tuesday, March 15, 2011 6:50:09 PM(UTC)
dalemorris
if anyone knows how to fix that door opener, the button that pushes in to unlatch the door is not working and I have to push way to hard and pull door from top to open
DM924 Dacor Microw
HELP
Guest
#3 Posted : Sunday, November 6, 2022 11:26:43 AM(UTC)
Guest
Rank: Guest
United States
I just bought a new one and have the same problem. Did you find a solution or is it just a bad design.
