wlbowen
#1 Posted : 15 years ago
wlbowen
The door release is not working when I push the 'door open button' on the bottom of the control panel. How do I remove the control panel? Is there screws? Do I pry off the panel? If so, from what direction?
The 'hooks' on the door seem fine, it's the lever that pushes thehe 'hooks' up.
I assume the control panel has to be removed to get to the macanical parts that release the door.
dalemorris
#2 Posted : 14 years ago
dalemorris
if anyone knows how to fix that door opener, the button that pushes in to unlatch the door is not working and I have to push way to hard and pull door from top to open
DM924 Dacor Microw
HELP
Guest
#3 Posted : 2 years ago
Guest
Rank: Guest
United States
I just bought a new one and have the same problem. Did you find a solution or is it just a bad design.
