rocker5164
#1 Posted : Sunday, October 12, 2008 4:02:55 PM(UTC)
rocker5164
When i start the dryer it runs for approximently 5minutes and then it trips the circut breaker; could this be the result of a defective high limit thermostat and/or thermal cut-off ? I haven't checked the parts as of yet for continuity. just curious if there are other possibilities to consider.
Zanshin
#2 Posted : Sunday, October 12, 2008 4:05:21 PM(UTC)
Zanshin
Unless you have a direct short "which would be kinda obvious cause of the spark" I would say you have a weak breaker, how old is the house?
Drags1998
#3 Posted : Sunday, October 12, 2008 4:58:09 PM(UTC)
Drags1998
I agree with the weak breaker, But it wouldn't hurt to check the dryer out at the same time.
rocker5164
#4 Posted : Monday, October 13, 2008 11:30:17 AM(UTC)
rocker5164
Thank you so much !; it was in fact the breaker. The breaker was a 40 amp and the guy at Home Depot said I needed a 30 amp so i installed it today and ran the dryer for a cycle to test and make sure that it was working properly. I am happy there are places like this here on the net to help poor souls like myself. Thanks again , rocker5164:)
Guest (4)
Breaker trips after 45 (Dryer Repair)
by Ken Martin 7/26/2011 12:56:42 PM(UTC)
by Ken Martin 7/22/2011 7:39:35 AM(UTC)
Circuit Breaker Trips when Mircrowave is turned on (Microwave Repair)
by nc4362 6/10/2008 6:27:55 AM(UTC)
Breaker trips (Dishwasher Repair)
by jim1958 11/12/2007 9:06:10 AM(UTC)
