4 Pages<1234>
wb2tbb
#21 Posted : Friday, March 4, 2011 10:30:44 AM(UTC)
wb2tbb
Originally Posted by: magician59 Go to Quoted Post
The Suspension springs (there are 6 of them) attach the outer tub assembly to the machine base. You should be able to see them as soon as you remove the front cabinet panel.
Part number: AP4024545
The snubber goes between the brake assembly and the machine base.
If it is worn badly enough, you will often see shavings or fragments of shredded nylon.
Thank you ...I will take it apart and have a look this weekend.
....Dave
wb2tbb
#22 Posted : Monday, March 14, 2011 6:54:46 AM(UTC)
wb2tbb
....Dave
I have this washer apart, and tipped now. Those springs you mentioned are in place, and in good shape. I had a question about the motor.
Is it supposed to be solidly in place?
Mine is rubber mounted on a plate. The motor is mounted to the plate with rubber and teflon washers. But I can slide the motor around on the plate about an inch and a half forwards and backwards. Could this be the cause of the violent wobble?
magician59
#23 Posted : Monday, March 14, 2011 7:19:25 AM(UTC)
magician59
The motor is designed to pivot on that mounting plate. Thet's the manufacturer's answer to the clutch, in an effort to make the machines more affordable.
Try removing the front panel and selecting a Spin cycle. Observe the action to see if you can spot the cause of the vibraton. One possible cause is a worn snubber. That's the nylon ring between the brake assemby and the machine base.
Part number: AP4024496
wb2tbb
#24 Posted : Monday, March 14, 2011 7:34:32 AM(UTC)
wb2tbb
Doing what you said, I think I noticed at least part of the problem.
One foot was about the thickness of a nickel off the ground. This is because the feet are metal, with a rubber boot. One of the rear ones, the rubber boot is all dry-rotted, and not there. So I adjusted one of the front feet, and while the tub now vibrates a bit, and slowly moves around....the machine does not dance across the floor. Are the feet covers replaceable?
magician59
#25 Posted : Monday, March 14, 2011 7:56:38 AM(UTC)
magician59
Here's tha part number for the entire leveling leg. You might try calling the number for customer support to see what the part number for the rubber tips is.
Part number: AP4027856
wb2tbb
#26 Posted : Monday, March 14, 2011 8:10:22 AM(UTC)
wb2tbb
clicking on that part number, I get.....
wb2tbb
#27 Posted : Monday, March 14, 2011 8:15:14 AM(UTC)
wb2tbb
We found no matching parts for " AP4027856".
I found it by putting the number directly in, but that is not mine.
I have a thread in foot 1 3/4" long, and the threaded part is 1/2" diameter.
magician59
#28 Posted : Monday, March 14, 2011 8:34:33 AM(UTC)
magician59
that was the one listed as the leveling leg for the rear. Try this one for the front:
Part number: AP4034169
wb2tbb
#29 Posted : Monday, March 14, 2011 8:41:13 AM(UTC)
wb2tbb
That is it! But it is actually the rear that has the rubber part missing. I just grabbed the front one because it was easier to pull off. Now I learn the front are not the same as the rear. So, if the rear does not unscrew like the front, does it remove easilly?
magician59
#30 Posted : Monday, March 14, 2011 8:48:17 AM(UTC)
magician59
Not as easily as the front legs.
Guest (5)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Maytag MAV7600 will not spin a full wash load (Washer Repair)
by dfab 10/14/2022 11:13:21 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool LAT2500AAE Washer agitates one direction only and will not spin (Washer Repair)
by spmelick 3/21/2022 4:02:10 PM(UTC)
Whirpool washer will not spin (Washer Repair)
by Guest 1/27/2022 11:02:31 AM(UTC)
Washer Will Not Spin Out Water. (Washer Repair)
by Guest 6/5/2021 1:32:58 PM(UTC)
Cabrio will not spin or agitate (Washer Repair)
by Johneb06 1/19/2021 2:52:49 PM(UTC)
Kenmore Front Load Agitates, but will not spin (Washer Repair)
by krusen 1/2/2020 7:56:09 PM(UTC)
GE Profile Harmony washer will not spin - grinding (WPGT9150HWW) (Washer Repair)
by jmac2287 12/3/2019 11:25:46 AM(UTC)
Maytag MVWX655DW0 will not spin (Washer Repair)
by radams925 6/29/2019 9:50:29 AM(UTC)
Maytag A9200 Will Not Spin (Washer Repair)
by spirittoo 10/31/2018 1:58:04 PM(UTC)
GE no faults, will not spin on regular wash (Washer Repair)
by dekk_ks 3/28/2018 8:23:06 AM(UTC)
Washer will not spin (Washer Repair)
by lftfield09 6/9/2017 4:58:09 PM(UTC)
Stacked Washer dryer- washer will not spin and empty (Washer Repair)
by anderson3818 6/8/2017 7:57:48 AM(UTC)
washer will not spin out.. (Washer Repair)
by coastie1160870 1/11/2017 10:41:54 PM(UTC)
4 Pages<1234>
