ericbeerman
#1 Posted : Saturday, October 11, 2008 11:00:59 AM(UTC)
ericbeerman
I have an older Kemore Compact refrigerator (6.0 cubic feet Model 91608). The freezer part got loaded with ice and the refrige cut off and I saw some water on the floor. I unplugged and let it slowly defrost over a 10 hour period while at work. Then I plugged it back in and set the control at the #4 setting. The inside light works but the refrige won't start or come on. It won't cool. It has been 24 hours. I tried turning it on and off but it still won't work. Please advise. Thanks for your help. Eric
v2k04
#2 Posted : Saturday, October 11, 2008 11:49:22 AM(UTC)
v2k04
Well it's either the electricals on the compressor Relay, overload or the Compressor bit the dust working so hard when it was frosted over
ericbeerman
#3 Posted : Saturday, October 11, 2008 12:10:35 PM(UTC)
ericbeerman
Hey v2k04,
Thanks for the help! I appreciate it! I am not very experienced with refrigerator repair. I looked at the electrical plug that plugs into the compressor (is this the relay?) and visually it looked OK (was not melted). When I did I noticed that the compressor was very hot (it had been plugged into the power for about an hour. I could touch and keep my hand on it, but it was hot. Also, I found the correct model number (126.8916081) for what it is worth. Do you have any suggestions or should I just toss it and get another one?
v2k04
#4 Posted : Saturday, October 11, 2008 12:20:49 PM(UTC)
v2k04
Those little compressors won't handle much abuse. Like the bigger ones will. You can pull the relay off the terminals of the compressor if its a solid state style you can shake it and if it rattles its bad if its the plunger style where you can see copper wraped around a coil it will rattle. If it is more than 5-8 years old I would by a new one it would be cheaper than having someone come out and fix it or tell you the comressor is shot. You can pick a relay up any appliance parts store for about 25 bucks and see if that fixes it Your comprssor has 3 terminals on it that look like steel pins sticking out of it in a triangle pattern you have the common, Start winding, and run winding when voltage is applied to the start winding it powers it up then drops from the circuit and in a nano second the run winding gets power and it runs well if it cant start it just sits there and gets hot or burns up the windings
ericbeerman
#5 Posted : Saturday, October 11, 2008 12:38:57 PM(UTC)
ericbeerman
Hey v2k04,
Thanks for the prompt reply and great advice. I appreciate it! Have a great weekend. I think I will look for a replacement. Someone gave me this one and I have had 2 good years from it. I WILL be sure to not let my next one ice up like this one. What was I thinkin'? Just being lazy I guess. Some of us (me) have to learn the hard way. Eric
Guest (4)
