I get water in and it pumps out fine but it wont wash,when it goes to wash cycle I get a hum for about 5 seconds then nothing,but it will pump out the water and refill
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
That hum you hear is the motor attempting to start , this can be caused by a number of isses, the most common would be "something" stopping the motor and macerator from turning, not a tough task to get into the pump, remove the lower impeller and using a torx 15 bit unscrew the upper pump assembly, keep going until u see a screen and metal "blade" and make sure it can turn freely, a bad control board or the motor itself would cause same thing
