randy19668
#1 Posted : Friday, October 10, 2008 3:17:23 PM(UTC)
randy19668
I get water in and it pumps out fine but it wont wash,when it goes to wash cycle I get a hum for about 5 seconds then nothing,but it will pump out the water and refill
randy19668
#2 Posted : Friday, October 10, 2008 3:22:35 PM(UTC)
randy19668
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Zanshin
#3 Posted : Friday, October 10, 2008 3:27:34 PM(UTC)
Zanshin
That hum you hear is the motor attempting to start , this can be caused by a number of isses, the most common would be "something" stopping the motor and macerator from turning, not a tough task to get into the pump, remove the lower impeller and using a torx 15 bit unscrew the upper pump assembly, keep going until u see a screen and metal "blade" and make sure it can turn freely, a bad control board or the motor itself would cause same thing
randy19668
#4 Posted : Friday, October 10, 2008 3:32:51 PM(UTC)
randy19668
THank you for the info
