THESUNVOL
#1 Posted : Friday, October 10, 2008 1:05:39 PM(UTC)
THESUNVOL
I have an up right freezer that the drain in the bottom of it keeps freezing up and was wondering how to keep it from doing that
kayakcrzy
#2 Posted : Friday, October 10, 2008 1:49:41 PM(UTC)
kayakcrzy
Of course be possitive that you have it clear, and then look at the front of the freezer, it should be higher then the rear. So when you let go of the freezer door, it will close by itself. Tom ApplianceEducator.com
Zanshin
#3 Posted : Friday, October 10, 2008 3:46:04 PM(UTC)
Zanshin
They make "heater probes" that are made from aluminum and wrap around the lower heater portion to transfer heat, just be sure its only in the defrost drain and not touching anything else.
libertyappl
#4 Posted : Friday, October 10, 2008 8:28:58 PM(UTC)
libertyappl
The defrost drain heater part number we use is SH250.
Nat
up right freezer always running (Refrigerator & Freezer Repair)
by dday 11/16/2010 2:01:45 PM(UTC)
