teddy99520
#1 Posted : Sunday, June 28, 2009 1:23:21 PM(UTC)
teddy99520
I have the washing machine apart, took the old clutch off and have the new replacement clutch on the shaft. For the life of me I can't get that miserable retainer ring back on. What is the trick?
#2 Posted : Monday, June 29, 2009 2:43:41 AM(UTC)
Pry the c clip on with a screwdriver, the retaining ring goes on top.
Brainiac
#3 Posted : Friday, March 11, 2011 7:26:52 PM(UTC)
Brainiac
Richappy - I posted a similar question today and just found this advice, however, I'm not sure what you mean. The retaining ring is spring wire-like and "C" shaped with a curly-q at the end which goes into a hole in the clutch assembly. I'm confused.:confused:
#4 Posted : Saturday, March 12, 2011 12:49:52 AM(UTC)
Put the wire c clip bent end in the hole and work the rest of it in place with a screwdriver.
