wwjak@bellsouth.net
#1 Posted : Friday, October 10, 2008 9:32:39 AM(UTC)
wwjak@bellsouth.net
Washer,pull button to start,nothing. Checked fuse behind front cover,blown.Replaced,Water fills to proper level,but nothing else happens ,checked wiring diahgram,thinking its the check switch failed causing fuse to blow and timer control not to function?
kayakcrzy
#2 Posted : Friday, October 10, 2008 1:36:33 PM(UTC)
kayakcrzy
You also have a small micr switch next to the fuse, and another lid switch, usually black, and rectangle shape, it will be 1 of those. Tom ApplianceEducator.com
v2k04
#3 Posted : Friday, October 10, 2008 2:19:48 PM(UTC)
v2k04
Replace the whole assembly that houses micro switches and fuse Maytag part number is 22001682
kayakcrzy
#4 Posted : Friday, October 10, 2008 3:55:50 PM(UTC)
kayakcrzy
Yes, that is correct. Let me know how it goes. Tom ApplianceEducator.com
