the buttons on the control panel don't work. just the cancel button. it goes through cancel but it won't wash. and the lights on the buttons don't work . whats wrong with this thing ?
Originally Posted by: Millard Dunn  the buttons on the control panel don't work. just the cancel button. it goes through cancel but it won't wash. and the lights on the buttons don't work . whats wrong with this thing ? Millard, Could not find the model number you supplied, could you please varify and repost the model number, for more accurate information. In the mean time, You could try removing the control panel from the door assembly, Disconnect the key pad ribbon from the control board, and clean the insertion end with alcohol, and re insert the ribbon tightly on the control board ribbon connector, it may help solve the problem. Thanks, :) :) :)
