edtrade
#1 Posted : Friday, March 11, 2011 3:15:35 AM(UTC)
edtrade
Our Maytag washer model MAV4758AWW has begun to spin slow. The water drains quickly. But the spin isn't fast enough to ring out the cloths anymore. I noticed the drive belt seemed glazed over (worn) so I changed the drive belt but the spin cycle remains the same slow speed. I also removed the agitator and nothing was found under it to be binding the tub.The tub spins smooth and free by hand without squeaks or noises all the time and also it's quiet when its running through the cycles. So now what should I look for as the problem for a slow spin? Electrical or mechanical?
Jeff / APP Team
#2 Posted : Friday, March 11, 2011 12:28:56 PM(UTC)
Jeff / APP Team
Hello edtrade,
Check the thrust bearing kit at the bottom of the washer and make sure it is releasing the brake assembly properly. If it is loose or worn, you will need to replace the kit. Here is the part number for you. Hope this helps. Part number: AP4009132
Slow spin - clicking drum (Washer Repair)
by Machine_Slo 1/6/2020 9:18:40 PM(UTC)
Noise during the fast spin cycle, but not slow spin cycle (Washer Repair)
by onthego4858 6/17/2017 10:18:24 AM(UTC)
Slow spin cycle (Garbage Disposer Repair)
by Cbus 4/26/2016 11:35:11 AM(UTC)
Whirlpool top load very very slow spin (Washer Repair)
by Docken 10/22/2014 5:31:26 PM(UTC)
Intermittent stuck on slow spin (Washer Repair)
by pmhstar 4/28/2014 10:58:36 AM(UTC)
No agitation and clicking during slow spin (Washer Repair)
by Whirlpool ray 12/6/2013 8:54:59 PM(UTC)
Whirlpool top loader slow spin cycle (Washer Repair)
by Re Vera 6/24/2013 12:34:34 PM(UTC)
Intermittent Slow Spin (Washer Repair)
by imageshift 4/2/2013 8:49:27 AM(UTC)
by tresor 1/21/2013 4:55:38 PM(UTC)
by twg2 4/26/2012 7:40:43 AM(UTC)
No spin or slow spin (Washer Repair)
by Morrisp 10/17/2011 1:02:27 PM(UTC)
slow spin and noisey in rinse cycle (Washer Repair)
by indoorairpro 9/25/2011 8:34:40 AM(UTC)
Leak & Slow Spin (Washer Repair)
by 4evrmoor 4/20/2011 9:14:26 AM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
Maytag washer slow spin (Washer Repair)
by Handyman3 1/25/2011 7:14:40 AM(UTC)
