decarteret
#1 Posted : 16 years ago
decarteret
My stove needs a couple of these AP97906 parts (lens, indicator light) but unfortunately the manufacturer doesn't make them anymore.
Does anyone have an idea if it's possible to get a replacement for them anywhere... or maybe suggest an alternative way to attach the actual indicator light? The light warns you that the cooktop is still hot.
Drags1998
#2 Posted : 16 years ago
Drags1998
Check to see if another Make will fit. alot of these small parts are the same between diff. brands.
libertyappl
#3 Posted : 16 years ago
libertyappl
Do you have the manufacture part number, might be able to cross reference them for you.
Nat
krothermund
#4 Posted : 16 years ago
krothermund
I talked with the manufacturer and the part number is 31780502.
libertyappl
#5 Posted : 16 years ago
libertyappl
According to the breakdown you can order a different indicator light and different lens.
Model ACS7270AS
Here's the breakdown
Part # AP2669412 & Part # AP250711
Nat
decarteret
#6 Posted : 16 years ago
decarteret
Wow, that's it! Perfect! I can't believe the answer was right there in front of me the whole time.
libertyappl
#7 Posted : 16 years ago
libertyappl
Hope that works for you.
Nat
