My stove needs a couple of these AP97906 parts (lens, indicator light) but unfortunately the manufacturer doesn't make them anymore.
Does anyone have an idea if it's possible to get a replacement for them anywhere... or maybe suggest an alternative way to attach the actual indicator light? The light warns you that the cooktop is still hot.
Check to see if another Make will fit. alot of these small parts are the same between diff. brands.
Forum Rank:: Advanced Member
Do you have the manufacture part number, might be able to cross reference them for you. Nat
I talked with the manufacturer and the part number is 31780502.
According to the breakdown you can order a different indicator light and different lens. Model ACS7270AS Here's the breakdown Part # AP2669412 & Part # AP250711 Nat
Wow, that's it! Perfect! I can't believe the answer was right there in front of me the whole time.
Hope that works for you. Nat
