how do I remove the pump from this washer since it is beltless and attached to the motor?
Just remove the two metal clips holding the pump onto the motor.
the easiest way is to remove the screws from the control panel flip the control panel up on it's hinges then remove casing, front,sides,top all come off as an assembly from there you can see the pump attached as mentioned by two clips remove the clips and hoses and remove pump
